edlee
- Western Massachusetts
I don't understand electronics, maybe someone can explain. Flickering LED problem in 3 fixtures on one switch is resolved by installing one incandescent lamp. But it's a little more complicated than that, because the flickering is caused by a dimmer controlling a different light fixture:
In a residential kitchen/dining area we altered some lighting. 3-gang existing switch box, new wiring by others. 3 pendants over a peninsula with A19-style LED lamps on a dimmer. We swapped the dining room light fixture, which will soon have LED lamps but temporarily we installed incandescents. We installed a new LED-rated dimmer for the dining room fixture. When the dining room fixture is dimmed, the peninsula LED's start flickering. It's variable depending on where the two dimmers are set, but clearly a problem.
We replaced one pendant LED lamp with an incandescent 60A19 and all the flickering stopped.
I think it has something to do with the straight resistive load vs. harmonics created by the dimmer, but I don't really know what I'm talking about. Any ideas?
