Leed Compliant Project
metallica5
Metro DC
Can anyone share their experience with LEED compliance on new construction of a municipal building. Construction management firm is looking for our plan on compliance with LEED for the electrical portion of the new construction. This is all new to me and I'm reaching out to anyone for any info or direction.
I don't know where your company or firm is in respects to designing or specifng what is going to be in the structure? It should have been a consideration way before you got hold of any plans, IMO. I frankly can't think of what concerns a construction management firm has in mind from or for you? If the cost saving measures aren't specified in a bid project, trying to get to LEED is at a total lost.
If they wanted you LEED cerifiied thats another story.
LEED is all over the internet, using the terms Electrical Leed gave these responses.
If you can post excerpts from the links that you are particularly interested in, we all might be able to interpret what they say and, equally important, what they don't say.
Looks like we need a little LEED primer. Fasten your seat belts ....
LEED is not a 'code' in any form that you would recognize. It is a certification issued by a private party that a project fulfills a number of that groups social goals. As such, the standards are essentially arbitrary and are most certainly NOT consistant from job to job.
The key to the certification is documentation of every aspect of a project. This includes everything from its' location, to whether there are bike racks or a bus line nearby. At the end of a job, the documentation is sent to this private group, where they review it and decide whether to 'certify' the place for a few years.
The review is based upon a scoring system. Various things are given 'points,' and the total score results in the certification of the building. The vast majority of the 'points' have absolutely nothing to do with saving energy, or even with the specifics of the building in question. For example, points are awarded if the place is in the inner ciity, or atop Love Canal. They WANT you to build in such places.
In some instances, LEED goals run smack into other code requirements. For example, they want as few lights as possible, while other codes and standards will want more lighting.
You're given points for using recycled materials. It's not enough to say 'I used steel pipe, and steel is the most recycled material in the world.' No, they want documentation from the manufacturer that the conduit contains X% recycled steel. You want to use the pipe you salvaged from another job? Lots of luck getting the Green Building Council to recognize that!
About all you can do as a contractor is follow the specs to the letter and let the chips fall where they may. The "LEED professional" is going to attempt to usurp the primary management authority on the job- so make sure change orders, RFI's, etc., are filled out.
Also: Be aware that LEED strictures WILL impact your access to the job site and your trash disposal. Don't be surprised if your guys have to park down at the bottom of the hill, and sort their trash between multiple dumpsters.
