jnaas2
- Evansville, In
Original install was 2 100 amp meters one fried and they replaced it with a 400 amp meter base with 1-200 amp disconnect and 1- 125 amp disconnect located outside sice both panels are 20 feet from the meter sockets. The original install was direct feed from the meter to the panel and I say since they installed the disconnect they made the panels inside sub panels and now they need to run the fourth wire and seperate the neutrals and equipment grounds since these are now sub panels WHATS YOUR OPINIONS
