I don't see a relationship between these two. If the building's design calls for a battery backup ballast, then it would be to provide egress lighting. If indeed egress lighting is required, and if you prefer to use a generator instead of the battery backup method, then that portion of the generator's distribution system would be classified as "emergency," and would be governed by NEC 700, and not "legally required standby," which would instead be governed by NEC 701.does anyone know when legally required system must be installed instead of a battery back up ballast
