Length of LFMC
Lefley
New member
Application is an 8-10' piece of 3 1/2" sealtight from a motor to a disconnect switch. As long as the flexible conduit is securely fastened at 5' from the motor (350.30(A)Exp2(3)) and securely supported, is there a limit as to the total length of the sealtight to the disconnect switch? Please respond.
I do not believe there is a length limitation for the install that you are doing.
