I am testing the resistance of an extension of the lightning protection with a clamp grounding tester. They tailed a single 4/0 from the ring to the top of a 20' of ground rod and the resistance is 20 ohms. To reach the minimum 10 ohms in the specs would you suggest creating a seperate loop for the rod or just add more to it.
