ptonsparky
Tom
- EC - retired
We had the second and by far worse ice storm this week. I learned that:
1. A 2.4kw generator will keep you warm and two freezers cold.
2. An 8kw will do the above, pump water and all the lights you need.
3. An 11kw will run a heat pump, 1st stage of backup, do laundry, plus the above.
4. A 300kw unit in spite of the mfgs assurance will NOT start a cold 100hp hammer mill unless you pick up the control voltage from a different source, and then only under great protest.
