The hole-hawg is heavy and very powerful, a possible wrist-breaker...........
Same here, 1/2" RA Milwakee with an 1 1/8" auger bit, plus an 18" bit for top plates if you are under 6' tall. Adjust the handle so it's 90 degrees from the chuck. Drill top plates right next to studs (left side) and use the stud as a brace.
If you are roughing a BUNCH of houses, get the angled extension.
Hole Hawg is too much of a beast. You get better leverage wit an RA drill and it seems like 1/2 the bulk/weight
which one out of these two?
http://www.homedepot.com/webapp/wcs...&prodComp_1=100609422&N=10000003+90401+500859
Here is a picture of the gooseneck I used. There is little need for a ladder in standard 8ft ceilings, and virtually no bending down as well for lower holes. I used these many, many years.
Where do you get those nail plates for air? Those would come in handy many places. I'm sure you use an air tool, but what kind of fastener do they use? :grin:Here is a picture of the gooseneck I used...
