Greg1707
- Alexandria, VA
- Business owner Electrical contractor
I installed a Leviton panel for the first time yesterday. There is a learning curve. There are some differences that required two calls to customer support.
We installed a WIFI power monitor in the panel. It connected to a two pole breaker. It has two hots and a neutral. It did not work at first. I called customer support and they advised me to verify the neutral was connected to the terminal adjacent to the N on the breaker, After making the change the device worked.
I don't understand. I assume all of the neutral terminals are connected together?
How did moving the neutral to a different terminal on the panel solve the problem?
