I have a customer who is interested in the Leviton wireless switches and controllers. The power pack receiver is WSP20-9D0 (relay power pack).
I'm curious if anyone has worked with these and what your success was.
Can you say some more about the Leviton wireless product line. It sounds as if it could be helfull in many situations. Where does it work best? Where not so good?
If used within the guidelines in the description I don't see how you can go wrong. The majority of other installations have been the Lutron Caseta series with wireless Pico controller but those say the range is 30' however I have used it at 60' with open line of sight.
If it's a decent sized project your wholesale house should give you the number of the local Leviton rep who will come meet with you and help pick out the products best suited to your application.
I've used Luton Cesta as well, with a range of approx 60' with no problems. I've also done a mix of Caseta Pro dimmers and mechanical 3-ways and then Caseta switch or dimmer with pico at other end. All seem to work great.
