LFMC as a ground
augie47
Tennessee
Art 250.118 address using LFMC as a grounding conductor and limits the use of the raceway as a grounding means to a 60 amp circuit on sizes 3/4-1.1/4.
On sizes larger than 1-1/4 " can LFMC be used as the sole equipment grounding means ?
Here's the code wording, no mention for larger than 1.25". Also if it's used for flexibility then it must have a wire type EGC.
250.118(6) Listed liquidtight flexible metal conduit meeting all
the following conditions:
a. The conduit is terminated in listed fittings.
b. For metric designators 12 through 16 (trade sizes
3/8 through 1/2 ), the circuit conductors contained in
the conduit are protected by overcurrent devices
rated at 20 amperes or less.
c. For metric designators 21 through 35 (trade sizes
3/4 through 1 1/4 ), the circuit conductors contained in
rated not more than 60 amperes and there is no
flexible metal conduit, flexible metallic tubing, or
liquidtight flexible metal conduit in trade sizes
3/8 through 1/2 ) in the ground-fault current path.
d. The combined length of flexible metal conduit and
flexible metallic tubing and liquidtight flexible
metal conduit in the same ground-fault current
path does not exceed 1.8 m (6 ft).
e. If used to connect equipment where flexibility is
necessary to minimize the transmission of vibra-
tion from equipment or to provide flexibility for
equipment that requires movement after installa-
tion, an equipment grounding conductor shall be
installed.
