LFMC Grounding
chuckwhite824
New member
Paradise, CA
I plan to run 15ft of LFMC cable (3/4" UL) from control panel to PVC conduit for powering an external Motion Sensor light. Inside the PVC and LFMC cable will be UF-B cable. According to code, the UL LFMC cable is grounded. Do I need to ground it more formally or should I limit the LFMC run to 6 ft. or less? Thoughts?
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
