I hate LFNC with a passion. The only advantage I can think of is if using between non metallic enclosures, one would have to use a BB on one end of the LFNC.What are the benefits of using LFNC over LFMC besides some cost saving? Per code, both can be longer than 6 feet if support properly and has ground wire pulled.
It's good for AC condensers and I sometimes use it for sleaving water heater wires since it's clean vs FMC which has an oil on itI hate LFNC with a passion. The only advantage I can think of is if using between non metallic enclosures, one would have to use a BB on one end of the LFNC.
Have fun with it. I hate the stuff with a passion, absolute garbage and never use itIt's good for AC condensers and I sometimes use it for sleaving water heater wires since it's clean vs FMC which has an oil on it
Ever wire up a packaged spa without it?Have fun with it. I hate the stuff with a passion, absolute garbage and never use it
In an application with a lot of vibration, I have seen the insulation on the conductors wear through and ground out on the inner metal of LFMC.What are the benefits of using LFNC over LFMC besides some cost saving? Per code, both can be longer than 6 feet if support properly and has ground wire pulled.
Yes, I use LFMC for those.Ever wire up a packaged spa without it?
Well, yeah!
Good to know, maybe I'll give it a try. Definitely just seems like LFNC could be much much better, with a different material having more flexibility, lower coefficient of friction, better fittings, etc. Perhaps the product standard needs some updating.There is a difference between mfgs of LFNC. Carflex and associated fittings are junk. I used T&B black LFNC and nylon bullet connectors, quality and tough. A lot of what I wired was instrumentation in in underground damp vaults that had non metallic enclosures so the LFNC worked well were with that. Try the T&B you may like it,
For motors, transformers, the LTMC works best
