hambone1216
- Rochester new york
Having problems with a group of six MH250/m58/u lamps burning out signifigently before the suggested 10000hr. life span. Average actual is 1000-1600hrs. Supply voltage at each head is 212-216 volts. Using 208v taps on the Advance Adapter ballasts and wiring in the following(Line1-208 tap:Line2-common tap: cap1-cap tap: cap2-lamp center: lamp shell-common: grnd-housing) the only cause that i see is the slightly higher voltage. Any ideas?
