jmsbrush
- Central Florida
Guys ,what do you charge for a small scissor lift if needed for a 1/2 day and for a full day?
Thanks.
Thanks.
whatever the rental company is charging. ......
Whatever you do, never, never let the customer rent the lift. You will lose lots of $. They will get some broken down thing your employee will try to fix and lose lots of $. Or it will not be there and they do,t care your worker had to drive 80 miles and you lose 4 hours of his work. They will expect you to do the work for the same price too.
I climbed into a customer supplied boom lift one time and started raising the bucket. When I tried to stop it just kept going up and then it started rotating in circles. I tried the emergency shut off switch but nothing would make it stop. It finally stopped after awhile. They had left it out in the rain overnight and I guess the controls were full of water causing it to have a mind of it's own.Whatever you do, never, never let the customer rent the lift. You will lose lots of $. They will get some broken down thing your employee will try to fix and lose lots of $. Or it will not be there and they do,t care your worker had to drive 80 miles and you lose 4 hours of his work. They will expect you to do the work for the same price too.
