I installed two new electronic ballast fluorescent fixtures in a older home the other day.(One feed, with a chase nipple between, bonded together) They were hung in a room that used to have a spa in it. I powered them up from a existing light fixture rough in. The 120 volt branch circuit that feeds the lights and receps are on a 20 amp GFCI breaker. After I installed the new fixtures, I could not get the GfCI breaker to hold. I started doing some troubleshooting, and found that every time I would take the ground wire off the fixtures, so they were ungrounded, the GFCI would hold. I did some checking with my meter, and found that I had 120 volts from my fixture frame to my branch ckt ground when the lights were energized and lit. My thought on this was that the 120 volts was purely magnetic induction from the ballast of the fixture inducing voltage on the metal parts.
The neutrals and grounds in the panel are all bonded together also. My thought is that I am creating some type of ckt with the magnetic induction. When I don?t bond the fixture I don?t have a secondary. Thus, my hot to neutral ratio back at the GFCI breaker sees a balanced current between, hence no trip. When I ground the fixture I have current leakage somehow and I don?t have a balance between my hot and neutral. Even though its on a GFCI I can?t leave the fixtures ungrounded, and am reluctant to put standard breaker in its place until I get to the bottom of it.
Any other thoughts would be great. Thanks
