I am making a light fixture using a 2 meter LED strip light. It will be under 30 watts at 24 vdc. I want to hang in by 2 solid stainless steel wires at .031" diameter each, with each wire attached to each side of the light strip, with the other ends going to the LED driver. The wire will be no longer than 10' long each. Can you tell me if this will be OK?
