Light fixtures near a hottub in an enclosed gazebo with
matt1972
I am a homeowner in Illinois and have a question regarding light fixture placement inside the gazebo. The fixtures are wall mount and on all four sides of the structure and are each less than 5 feet horizontally from the water surface of the tub. The electrician called today and said they didn't think it would work. The village elec inspector is on vacation until Wednesday and this is a major impediment. Earlier, the elec contractor (the owner of the company) had sent me an article from IAEI News July/August 2003 when we were thinking about putting a ceiling fan above the tub that talked about the height we would need. In that article, it describes light fixtures and how close they can be. The articles reads that for an indoor spa or hot tub, luminaires and celing fans located less than 12 feet above the spa and within 5 ft horizonatlly must be GFCI protected. It also states that luminaires and ceiling fans cannot be located within 7.5 feet above the water level of an indoor hottub with the exception of surface mounted or recessed luminaire with a glass or plastice lens or globe, nonmetallic or electrically isolated metal body or trim and suitable for use in damp locations.
Also, above the hot tub are two skylights that are electric powered and although they are recessed into the ceiling, they are less that 7.5 feet at their lowest point from the water level.
How do you tell if an electrical fixture has electrically isolated trim? The fixtures are approved wet location but do have some metal trim.
The elec inspector when he reviewed the plans said that everything was ok and must follow article 680 of NEC.
Any input from you all would be appreciated. I have referenced the electrician who called me to the article his boss sent me so we'll see what his take is on it.
Thanks,
Matt
[ August 29, 2003, 01:24 PM: Message edited by: matt1972 ]
G
Guest
Guest
Re: Light fixtures near a hottub in an enclosed gazebo with
First off, I would say you posted in the wrong forum topic area. This area is for AFCI questions. In conclusion, I will offer three words:
CAN
of
WORMS
images
You can of worms is much larger than this one. You have an accident waiting to happen. If you can touch it, it's too close.
matt i am not an electrican but, i will say get everything gfci protected and by an electrican. and here in texas my inspectors do not consider a gazebo to be indoors like a hottub in your living room would be.
al
