I'm a old sparky and still use wire nuts. I stripe #16 to #10 guage wires 7/8" of a inch then pre twist along with a final tighten with heavy side cutters, trim the ends even, install wire nut ( pressure connector ) then give them a final tighten with heavy side cutters so connection has at least halve a turn of insulation portion then install quality tape. Wired in so many vibrating screens, hammer mills, shakers and other equipment that had a lot of vibration this way of making splices never failed. Checked prices a few times on Wago & copy cat brands of connectors and they always cost more then wire nuts so most sparkies will go with the cheaper wire nuts. I have at least six boxes of wire nuts in my garage and three state pre twisting not required, two state to pre twist and a oldy but goody box of wire nuts from the 1970's that are approved for splicing copper & aluminum wires in dry locations doesn't have any opion.
