deb4523
- Alaska, USA
I need to measure the available light at a gate to make sure it meets regulations here. However, the ground is snow covered right now. I can not wait till it melts because this needs to be part of a summer project, going out for bid in advance. Also, we have a lot more darkness now than we do once the snow melts, so it would be easier (time wise) to measure now.
Does anyone know how much of a difference the snow makes when using a light meter? Is there a standard way to compensate for it?
(I tried internet searches, but was only able to find information for photography light metering in the snow... how to adjust the camera, etc.)
The area is very flat with no nearby trees, if that makes a difference. I need to measure the light at ground level.
If the available lighting does not provide enough light, I will have add additional lights to the project...
Thanks!
Thanks!
