I know this is a subject that Mike Holt is really hot on from some of the things I've read on his site i.e. parking lot pole grounding.. Question is-- we are mounting new light poles on a passenger platform at one of our rail stations. The drawings show a ground rod driven under the platform at each pole location,#4 ground to 10' rod. We have one lug in the pole. Should the circuit ground from the panel and the internal light pole ground all be under one lug with the ground rod, or will we create ground loops doing it this way? Also it's important to know that this is an electrified railroad running at 25 cycle (light poles are 277v at 60 cycle). We do a lot of bonding at the passenger locations i.e. railings and metal structures but we try not to bond the 60cycle to the 25cycle. I probably over complicated the picture with the 25 cycle story but even disregarding that should we bond under a seperate lug at the light pole. I'd like to hear your opinion... Thanks
