Beachjumper
New member
Any code covering painting, over spraying, light switches and receptacles in a single family dwelling?
110.12(C) Integrity of Electrical Equipment and Connections. Internal parts of electrical equipment, including busbars, wiring terminals, insulators, and other surfaces, shall not be damaged or contaminated by foreign materials such as paint, plaster, cleaners, abrasives, or corrosive residues. There shall be no damaged parts that may adversely affect safe operation or mechanical strength of the equipment such as parts that are broken; bent; cut; or deteriorated by corrosion, chemical action, or overheating.
Too funny !!!Remember, we need both brains and a license to do our work - painters need neither !!!
I believe the answer is "yes" if the paper on the back of the plate extends within the box perimeter.Originally posted by iwire:
My Mom wall papers the plates (they can still be removed) is that a violation?![]()
This comes down to a matter of workmanship and being proud of what you do. You can paint the panel covers as long as you don't paint over the instructions and breaker legend on the inside. If you're a painter who cares about your work you'll remove the panel cover, paint it, let it dry and then re-install it on the cabinet. If you don't care you'll leave it on the cabinet and roller paint over it and seal it to the sheetrock.Do your inspectors allow the exterior of panels to be painted?
At least she covers the plates. My mother-in-law used to remove the plates and receptacle and then paper over the gem box hole because the receptacle wouldn't look right in that particular area.My Mom wall papers the plates (they can still be removed) is that a violation?
