adrnln8
New member
- Centennial, CO, USA
Hi All,
New to the forum, been doing a lot of research on the current problem we have and I'm not finding solutions so I've got to bug everyone with a new post. Thanks in advance for any help.
Doing a basement remodel/finish. Main Panel was too full to add the necessary breakers for the basement so we added a 70amp subpanel in a storage room of the basement. The basement will have a new bedroom so the owner has requested an AFCI breaker for that room. There are two light switches in the bedroom, one for the ceiling light and one for two Halo can lights above the head of the bed. Whenever the can lights are switched on, the AFCI trips. That switch is the last item on the circuit, furthest from the panel. So here's what I've done:
Initially the bedroom was on a regular 15amp breaker when we first powered up, everything worked fine, no issues. Then we installed the 15amp AFCI (correctly, I've checked 10 times) which turned on and held while we went to check receptacles and lights. Starting with the first switch from the panel, it was turned on and off successfully. Then testers were inserted into each of the three receptacles as we move down the circuit, those were all correct and fine. Then we came to the switch for the can lights - pop. Damn. So I checked the wiring from the switch to the lights, pulled all the connections out to make sure nothing was touching and tried again. Pop. Shoot damn, time to dig deeper. I took the second/last can light of the circuit, pop, took the first off and re-connected the second, pop, took them both off and flipped the switch - held. Now I'm confused. So what I did next is important and baffling - I rewired the lights, made sure nothing was touching and that everything was perfect and took the light bulbs out. I flipped the switch - held. Ok, so it doesn't like incandescent bulbs, well let's try, LED halogen and flourescent, pop pop pop. Ok, it's the damn can light fixtures, so I installed a keyless with a bulb at each location instead, pop. Took, the bulb out - held! Tried a brand new AFCI, same same same. Powered the switch leg through a nearby gfci and put in regular 15amp breaker - held. Hammer went flying across the room at this point, :rant: bought drywall guys some taquitos to fix the damage.
This is where I give up, advice please.
