tonype
- New Jersey
Not an issue as the code is silent on switches or receptacles in closets. I assume those are radio ra or some smart switches that are controlled by keypads.
Tried to research this... a grouping of light switches in a closet can be covered with clothing. Is there a provision that prevents this?...
I wired these ...
Well actually panels can be in clothes closets, you just can't have breakers in them.No code violation for switches in the closest. The only NEC reference is panels cannot be in the closet.
Roger
I mounted the center box first, then hammered the upper top and lower bottom nails, then drove the two of which you speak by placing the side of the tip of my Kleins against the nail heads and hitting the hinge area (the fixed side) with the hammer.Off topic, but how did you drive (2 of) those nails?
How many circuits where in each box?I wired these in an upstairs loft closet for remote switching/dimming of lighting in a house we wired years back. (They're all pics of the same three boxes):
View attachment 23028 View attachment 23029 View attachment 23031 View attachment 23032
Transfers the impact to the nail and drives it as fast as direct impact does. I drive staples in tight places the same way. I learned this as a helper over 40 years ago.
I didn't remember, but a quick zoom into pic 2 shows only a single neutral bundle in each box, so I'd have to say one. In fact, it could all be on one circuit, or two.How many circuits where in each box?
That's why I always check, instead of trying to remember. :happyyes:don't ever make a mistake as to which side to hit. Did that on a lineman's once. OOPStook some time to work them loose again.
Why do you ask? (not to resent the question, but to continue the conversation)
Never. :happysad:I've seen a lot of guys have multiple gang switches with multiple Ckts and just tie all the nutreals together then ask y do they have a back feed
