Bigdogclancy
- Iowa
do anyof you have any case studies or experiences in lightening strikes causing injury or fatality to passers-by around lighting polls. Either steel or concrete poles. I am hoping some of you guys in the SE part of the country might have some first hand knowledge of happenings like this. I am trying to gather some information that would lead me to believe pro or con of the better type of pole for managing lighteining strikes. The steel pole offers lots of surface area to allow the travel of the current without lots of natural impedance from a high-frequency lighteining strike. I believe a properly grounded pole should not be a problem short of somebody leaning against it during a lighteining storm. And you can't account for that much stupidity. A concrete pole needs to either use a connection to its rebar cage or utilize a full length grounding cable. the rebar cage should work as well as the girder framework in a highrise building as far as conduction and dissipation of the current generation from lightening. But if the pole is damp and someone is leaning against it I would imagine that it could be jsut as conductive becausee of the porosity inherent to the concrete. Anyway just a couple of my thoughts. if anyone has anything to chime in with i sure would like to hear from you and discuss this topoic futher. thanks
