Rahim84
- Charlotte, NC, USA
Okay so I’m going to try to explain this the best I can. I pull up to my sons school and the handyman is trying to wire the outside walkway lights to a timer switch model # HET01 (I’ll attach a pic from google). He ask me to help because it’s not working right and he knows I do electrical work. So far he removed the regular light switch and now just has the cable coming out the wall. A single cable with what appears to be #18 conductors 24v kinda stuff.
So I see the 4 wire cable but at the panel it’s two 2 wire cables which I circled in blue, so I physically trace it out and see a splice in the attic. The ground is just cut off, the neutrals are spliced together. The red from the original cable is spliced to the red on one of the new cables and the blue is spliced to the red on the other new cable. So they come to what appears to be a relay, small transformer and into a two pole breaker in the panel. With regular #12’s actually going to the lights.
What I don’t understand is the point of this system because #1 the lights were being controlled by a regular switch
#2 with the entire switch taken off( wires spread apart like the pic shows) the lights were on. Even when I tried to make them trip or anything by placing them all to ground and even just touching them all to each other the lights stayed on. I got 21.1 V from Red to white. And from blue to white.
I just need some direction on what’s the point of all this and what direction I should take to get those lights on a timer
