Lighting calculator
nizak
Can anyone point me in the direction of a lighting layout calculator that utilizes LED.?
I have found several, but they all give me an answer in fluorescent.
Simply looking to find how many watts of LED lighting I need per fixture to light a pole barn to between 30/40 f/c's
I'd try this package http://www.visual-3d.com/tools/interior/
You at the bottom use the plus sign to add lamps desired once type found it, click it and it drops into design plain.
It doesn't have a lot of major led brands but it does show the Wattage and other technical specifications.
Look at http://www.rabweb.com/
After you pick a fixture, at the bottom right side of the page is a lighting layout designer. Click it and you can change any of the variables. Room geometry, foot-candles required at work height etc.
It the will give you a layout that you can customize and print.
I use it often, its quick and easy once you get the hang of it.
