I have a problem with one particular pole light failing to go off when its switched "off". Its operated by a Cutler-Hammer 5-pole,100 amp magnetic latched-type lighting contactor (A202K3EAM (?), 5277C15G26 Model M, C030911 as it's labeled).
In the "on" position, contactor pulls in and stays in okay. When its turned off the contactor fails to release.
The switch, coil, contacts,all appear in good shape. No obstructions. When I opened it up though, i did find some fine bits and pieces of metalic chips and plastic below the coil. Otherwise quite clean. I noticed some small indentions on the core and similar markings on contact block - what appears to might have been a small screw was bouncing around in there, hence the metal pieces.
If this were the case, I could see it not pulling in deep enough to make contact closure. But releasing is the problem. Switched to off, energized coil, should throw out the contact block, but its not. I suppose this "unintended gap"(created by a possible screw)could ruin the module or coil? Any suggestions?
