spinnakerdr
New member
I have installed a lighting contactor with a 24 Volt coil and I can control it perfectly when the length of the 24 volt wire is less than 20 feet. However when we tried to add a 3 way switch to control the contactor 225 feet away, the contactor will not engage. It buzzes like its trying and the voltage drop on the 24 volt side goes to 14 volts (current reads 2.2A). I have checked voltage drop for the wire used for the 3 way wire loop length (12 awg wire @ 550 feet loop length) and it should only be 0.56 volts at 0.5 amps. The contactor only draws 0.5 amps when it is on and holding. Maybe there is an inrush, but my meter cannot measure it. The transformer powering the 24 volt source is rated at 200VA. Thanks for the help.
