lighting contactors
biggladant
Kansas
When do I need to use a lighting contactor instead of a snap switch? My application is 4 400 watt MH highbays @ 240 volt. Am I ok with a double pole double throw snap switch? Would it be ok to put a 1500 watt MH @ 120 volt on a 20 amp snap switch?. Thanks
Re: lighting contactors
There is no need to start another post if you have a new question. Simply edit your existing post.
What does Ohm's Law tell you?
