Lighting contactors
sam34
Missouri
Please if anyone explain the different between Electrically held and Mechanically held lighting contactors and their different type of application. Thank you,
sam
Re: Lighting contactors
The power contacts are driven to both the open and closed positions by a momentary pulse of control power, therefore they are quieter than magnetically-held contactors because there is no continuous AC hum.
Mechanically-held contactors do not "drop out", and switch off the lighting during control power failures. During such failures, magnetically-held contactors usually drop into the "off" position, even though service voltage may still be available.
Ed
[ January 03, 2005, 06:56 PM: Message edited by: Ed MacLaren ]
The "classic" example of a mechanically-held contactor (latching contactor), is in a library where is is very quiet & you want to eliminate the possibility of hearing the alternating current hum of an energized coil.
There are of course, other applications.
if changing out bulbs for better designed versions does not fix a problem with humming in a dimmer switch, can contactors help eliminate the loud noise. Note, I've tried 3 types of dimmers now, none help the cause. Just curious if this is something viable or is there another option. I/ve had to use contactors once for a photo cell, but not sure of its application beyond this.
Don't see why a dimmer would generate audible noise except in the lamp itself unless the RF filter inductor is humming?
And, I wonder if the proximity of the filament to ferrous materials makes the filament vibrate more.
I also speculate that these vibrating filaments might fail prematurely.
But why a contactor, why not just replace the dimmer with a switch?
[ January 07, 2005, 12:45 AM: Message edited by: rattus ]
