bjp_ne_elec
- Southern NH
Have never had to install lighting contactors, but I have a job that I've volunteered some labor to the towns athletic fields. They were hit with a flood and most of the lighting contactors that were on the poles ended up under water. Haven't seen them yet, but I'd like some tips on what I might have to do in order to see if they're salvageable.
I'm going to go over next week, as they've got them all off the poles and in storage. My guess is they didn't bother to dry them out once the water cleared.
I'm assuming I'm going to have to go to work with a megger. Haven't had much experience with a megger - actually going to buy one - as it's an opportunity to add a new tool, and again, I'm assuming I'll need one to help out in this work that I'm volunteering to help out. I had originally just assumed I'd volunteer my labor to run the conduit, pull wire and make connections - but they mentioned the contactors once I signed up. I'm assuming they've got some contactors in them and then some control transformers - which are probably the two most sensitive items when it comes to damage by water. This poor field saw almost 8' of water on the field during the peak of the flood.
Is there some type of reference book that anyone is aware of, where I can read up on methods of using a megger to troubleshoot. I know it's one thing we used to talk briefly about in my apprenticeship training, but we never actually did anything as far as hands-on. And during my years as a journeyman, I never had to use one, as all my experience was new construction - and never had a problem that would have needed a megger to solve.
Thanks in advance
Thanks in advance
