Volt-Amps
- Indianapolis
I have 4 lighting circuits for a small project. 2 of them go to the exterior sign and show windows. The remaining two circuits feed interior lights. all 4 circuits are routed through a time clock for code compliance.
The 2 interior lighting circuits branch off 7 switch legs, each area/room/space has its own switch but at the end all 7 switches are tied to the 2 circuits mentioned earlier for interior lighting.
The client wants kill switches at 2 different locations (3-way switching). The intent is to be able to shut off power for all interior lights with one click. the 3-way kill switches to be located one in the office and one at the back door.
I thought of using a DPST switch, 2 circuits in and 2 circuits out, then route that through a contactor that has minimum 2 poles in, 8 poles out, and from there feed the switch legs. Please see attached proposed diagram. Keeping in mind to use a handle tie for the 2 breakers that feed the 2 circuits.
My questions:
My questions:
- Can DPST switches be wired as 3-way switches to achieve what I envisioned in the diagram?
- Is there a better or simpler way to achieve what the client wants? possibly using relays?
- I don't know much about relays, that's why I'm hesitant to call for something that is not possible to implement or build.
