Are the rules for control wiring in a lighting controller the same as for a motor controller?what I'm asking is,can #16 or #14 thhn stranded or machine tool wiring be used for the control wiring to relays or contactors coils that do not carry the actual load current in a lighting controller or ansul shutdown controller as long as the control wiring does not leave the enclosure?The control for most of these devices are drawn tapping off of a 20 amp lighting circuit (#12wire) that is on the line side of the contactor or if smaller control wiring is used does a smaller control fuse need to be installed to protect the control wiring itself?does the control wiring need to stay #12 since it is on a 20a circuit breaker?
