Does anyone know where I can find some white papers or non specific vedor information regarding the pros and cons of line voltage occupancy sensors and the use of a neutral conductor? I understand most manufacturers manufacturer both models (neutral / non-neutral) From what I have found these units (non-neutral) contain a power supply designed to generate the current necessary to operate the device , these versions use the ground connection to complete the relay circuit while producing a minimal amount of ground leakage. Just wondering everyone?s opinions on this and where I can find additional information regarding pros, cons, and where it would not be desirable to have a non-neutral connection I can imagine all new construction you would want the neutral? Does this violate any NEC or UL regulations rules I could not any. I wonder if the non-neutral is a UL listed device?
