Lighting greenhouse requires exit sign?
smallfish
Detroit
If a large public greenhouse 144 feet long by 30 feet wide has electric lighting then does code require illuminated exit signs? If so which code and section. Thanks
The requirement for exit signs would be in the building code typically and normally would be based on the occupant load of the particular use. If the occupancy is small enough, then exit placards could be used with lighting coming from the ceiling lights provided. As always, check with the AHJ for confirmation.
