A/A Fuel GTX
- WI & AZ
- Electrician
When laying out lighting circuits, how do you guys figure fixture totals when using LED's? For example, a standard 6" recessed can is usually rated for a 75W flood. For a 15 amp circuit, that would be roughly 23 cans per circuit. Now if LED's are used in place of the 75W floods ( 11W each in this case ) in the initial installation, can the circuit be designed with a greater number of cans to reflect the much lower LED power consumption?
