petersonra
- Northern illinois
- Semi-retired engineer
It is often convenient to install a lighting transformer in a cabinet that is powered from the line side of the cabinet disconnect.
Not a huge problem with a main disconnect switch. They generally have some screw terminals to connect small wires on the line side.
However, a typical MCCB does not. How do you guys get around this? Drill and tap the lugs on the line side? A common practice but seems like maybe not the greatest idea.
