sharan said:This is for a Warehouse aisles application, using T5HO fixtures. Can I use 30 amp branch circuits (to reduce number of circuits and panels) and 20 amp outlets in the ceiling? Fixture wiring to the outlet to be #14 (cord and plug).
LarryFine said:I don't see the 30a breakers as compliant.
It seems to me that the use of receptacles, even way above the floor, means that section does not apply here.weressl said:Seems to me 240.5(B)(2) addresses the issue.
infinity said:I'm with Dennis and Larry, no.
LarryFine said:It seems to me that the use of receptacles, even way above the floor, means that section does not apply here.
charlie b said:Why are we talking about receptacles? The question has to do with lighting outlets, not receptacle outlets.
Sounds like a lighting outlet to me. Sharan, can you clarify your question?infinity said:What is a 20 amp outlet on a 30 amp circuit? Sounds like a receptacle to me.
'Twas clear to me: 30a breaker and #10 wire (I hope!) supplying 20a receptacles (why not 15a then?), and #14 cords with plugs on the luminaires.charlie b said:Sounds like a lighting outlet to me. Sharan, can you clarify your question?
brantmacga said:That's dealing w/ flexible cord taps, not cord-and-plug connections. This code does not apply to the proposed installation.
