How does lightning really hit the transmission lines? Does it hit initially hit a single wire then spread it from there? But won't the wire melt. Or does lightning first strike the soil and it goes up to the transmission lines?
So the primary reason poles are grounded is for lightning strike to dissipate the energy into ground? What if a pole is not grounded. Would it damage the insulation inside the transformers? Has this actually happened elsewhere?
Please give me examples or incidents of transmission lines damages from lightning with and without grounding. Thanks.
