I have a similar question but it's regarding some 400hz generator
equipment that is pad mounted by the planes to supply power when on the
ground. I've not had a lot of familiarity with this equipment other than the
normal wiring connection to the electrical systems. They have told me since
I have been there that they have experienced a lot of costly equipment
failures due to lighting related incidents. There is an Equipment ground
conductor going to the ground at the main switch and 100' plus of
underground steel conduit bounded to the disconnect cabnet at the equipment.
I'm wandering if a ground grid should also be placed around the equip. and
bonbed to the cabinets as well?
