I'm trying to put together a design specification for a cellular signal amplifier to be placed in a home. The product contains an exterior antenna that is not grounded, and a lead in conductor goes into the building to an amplifier that is then connected to an indoor antenna. The installation instructions show no grounded surge protection for the lead in conductors. The question was raised -considering what Article 810.20 of the NEC says- if the NEC REQUIRES installation of a grounded lightning arrester or metal shield from the lead in that is grounded. If the code doesn't require it because the antennas are stand alone and therefore not grounded, and because there is no intrusion into the electrical wiring pathways of the home, we would rather not ground it or provide a path to ground because that would seem to increase the likelyhood of a lightning strike on the device, and also because of the reason below that came from the maker of the system.
Does anyone if we are REQUIRED by the NEC to provide the lightning protection described above?
"We have never tested the amplifiers to see if using a N connector with a grounding lug will change or effect the performance of the amplifier. We keep the path to the amplifier as clean as possible. We have to worry about external radiated signal as these units have passed both FCC and IC testing. Any other external connection could provide additional radiating paths for the signal which would void our FCC and IC grants.
Somewhere, somebody has to realize that the in building amplifier has an outside antenna, an inside antenna, and the amplifier case. There is no connection of any other type, to the CATV system in a building, electrical system, etc. The only connection we have is from a wall power supply that has a UL rating on it. This power supply converts 120 VAC to 12 VDC to enter the amplifiers independent power supply.
If lightning hits the external antenna, it will most likely destroy the in building amplifier. the AC power supply has internal fuse protection, but would probably be destroyed as well. There are no other connections to any other type of equipment.
I suggested a GFI outlet be mandatory for the amplifier as this would give you shorting and lightning protection to the system, be simple, and everybody can easily get one."
