Re: lightning protection
I have never heard of a license other than that which a state or government agent might offer. remember this state is behind times with license requirements. and the only thing I have ever been asked to do was to have a UL Master Label Certification inspection done. Which I might add is not easy to pass and the cost is not cheap. But this was done by the insurer for the building. There are many installations that do require even us as an electrician to do and allot of it is in the 800 sections of the NEC. Does that mean we have to sub contract out to do these requirement? I would think not. But to install air terminals, down leads. Bonding of all roof top metal. yes it does require some extra knowledge and as you know Dereck most in the electrical field would be lost if they had to do a cell site or a broadcast radio transmission tower with out the help of an engineer. But does this work require an engineer? Not if some has the correct knowledge. But most firms do when it comes to high tech equipment or large facility's that would be very susceptible to lightning damage. Most of these sites will have a engineer to spell out what has to be done, and follow up with the UL Master Label Certification inspection program to protect his butt.
By the way the UL Master Label Certification inspection program also uses NFPA 780, and UL 96A, Standard for Installation Requirements for Lightning Protection Systems when checking the installation.
