Lightning protection
JPM
New member
when sizing cable for lightning protection what factors are taken into consideration, and can any other material besides copper be used in this application?
Aluminum is utilized, for down conductors I have seen I-beams utilized. The LPS code NFPA 780 set the standards
Typically, the height of the building determines the size of the down cables (main cables). Class I verses Class, ect... The complexity of the system may result in large cables as a design consideration.
Many manufacturer's have cables and compoents listed for use under UL96 specifications that are other tan copper. This too is a design consideration unless specifically required by the NFPA 780 or 70.
