Please help if you can. This is the situation. A customer of mine had me doing some basic electrical work in his home. While I was there he mentioned that lightning has been a major problem for him. He said that lightning has damaged everything he had a couple of different times. He had another electrical contractor come out and that electrician drove another ground rod or 2. He now has 3.
I was wrapping up what I was doing and when I went to put the breaker in, I noticed he had 3 wire to his panel. The panel was in the middle of the house. I knew it was more than 15' from the meter base. I went outside and he also had a disconnect. Meaning, of course, the wire to the inside panel shoulda been 4 wire.
Now, my questions are:
Being this installation is wrong, is this in any way causing him more problems with lightning? I know this isnt causing lightning to strike his place, but once it does, is this affecting his appliances in the home?
What are the dangers of NOT having 4 wires to the secondary panel?
I appreciate all responses.
