bphgravity
- Florida
1. Nearly all resources I have read that describes the process of a typical lightning strike places the Earth (land) as an essential component. Streamers from grond-based objects connect to downward leaders from the sky. Yet at the time, it is estimated that up to 85% of the total lighnting strikes happen over water, namely the ocean and especially the Gulf of Mexico. If lightning is so intent on Earth (ground), why does it mostly strike non-land locations?
2. On the same note, I have read that it is estimated that 1 in every 5 aircraft flights are struck or effected by lightning. Again, no land or Earth involvement. Why is the NEC so positive that connecting the electrical system to Earth will assist in lightning protection?
3. Approx. $2 billion in loses to utilities in the US and over $1.7 billion in losses to homes from lighnting damage. As I recall, somewhere in the area of 300,000 claims are made a year to insurance companies from lightning damages. Do these figures indicate grounding of electrical systems are protecting against lightning? Do these figures indicate that all these occurances are because grounding was not adequate at these buildings and facilities?
Or, is this all evidence that it most likely does not make a bit of difference if your building and structure is effectively grounded as a matter of protection against lightning.
