Anthony3809
New User
- Lubbock Tx
- Apprentice Electrician
When I turn on my garbage disposal in the kitchen, the lights in the kitchen brighten for a half a second then go back to normal. What is causing this?
Welcome to the forum. Voltage drop can occur in any current pathway, but only a drop along a shared neutral can cause the voltage between a line and the neutral to rise as the voltage from the other line to the neutral droops.When I turn on my garbage disposal in the kitchen, the lights in the kitchen brighten for a half a second then go back to normal. What is causing this?
Well, he does say he's an "Apprentice Electrician".....so sounds like he's still learning.OP: you don't sound like an electrician.
Well, he does say he's an "Apprentice Electrician".....so sounds like he's still learning.![]()
