lmanderson
Designing lighting system over non-residential indoor swimming pool, don't have much horizontal space from the edge of an pool and a fairly low ceiling, will probably have to use GFCI lighting circuits based on NEC680.22. Probably single pole 120v breakers but could be 277. Will be using either fluorescent or metal halide for the general lighting. Anybody have experience determining the effects of inrush and ground leakage from lighting ballasts on the operation of the breakers? One manufacturer says they only have 120v single pole GFCI breakers, don't know if others have 277.
Just need to make sure whatever lighting system I design does not result in nuisance tripping, also any other issues I need to be aware of. Anyone with experience on this?
Thanks,
Linda
Thanks,
Linda
