jlelectric
New member
I recentley installed 6, 2x4 flourecent light fixtures. I put them on a 20 amp cbr. The cbr is in on a 120/240 three phase panel. The panel is being fed from 3 seperate transformers (one for each Phase) and is boosting each phase from 120 to 135 volts. I know I can go over or under 10% of 120, but I exceedd 120. The panel that is feeding the three seperate transformers is full. So my only option was the panel that is being fed by the transformers. Would this setup cause the lights to flicker and turn off and on ? Could this be caused by thermal overload? What would be the solution?
