In my opinion those things are not "likely to become energized". Is it possible that they will become energized, sure it is, but just because it is possible, does not make it likely.IMO, Gas piping, A/C ducting, water pipes are likley to become energized. ...
As best I can tell "likely to become energized" in the NEC means there is a remote chance of it happening.
Older editions of the NEC used the term "may become energized". That is the intent of the code rule and it should have never been changed from "may become energized" to "likely to become energized".I would call that "unlikely" to become energized.
IMO the phrase likely to become energized, as used by the NEC, is completely inaccurate as to what it's intended meaning is.
That makes even less sense. The items that are likely to become energized and require bonding by the code rules are typically not objects that are insulated.Soares states on page 27 of the Tenth Edition of Soares Book on Grounding & Bonding that the term is included in Annex B of the NEC Style Manual as a standard term meaning "failure of insulation on."
The way that I see it:
"Likely to become energized" refers to a piping or ducting that is part of a system that is connected to a voltage source. for example, gas piping that is connected to a furnace, ducting that is connected to a furnace, gas piping that is connected to a stove with an electric ignitor.
The gas piping system that is connected to a water heater only, is not likely to become energized.
I think what they are trying to say is a motor or pump is likely to have insulation failure at some point in its life. This motor or pump is well connected to metal ducts, housings, pipes, etc so they are likely to become energized.That makes even less sense. The items that are likely to become energized and require bonding by the code rules are typically not objects that are insulated.
